Gary Waugh
Okay, my 08 expedition has covered 250K miles and is now loosing coolant, unfortunately there are no traces on the ground, leading me to suspect that it has a failed head gasket (coolant leaking into the cylinder and going out the exhaust), but I am not getting any error codes for misfire, etc and the cooling system is not showing any signs of being over pressurized, I would expect a leaking head gasket to either leak to the outside world (but no external signs of coolant), or the pressure from the cylinder to leak back into the coolant system and cause the system to blow out coolant from the expansion tank (no signs of this either!).
I am going to check compression on every cylinder, but the engine idles beautifully and smoothly. I wanted to ask what are the known weak areas on the 3V 5.4Litre V8 engine? I know there is a plastic T-piece just above the RHS cylinder heads that fails (I replaced this a few years ago), it seems like the thermostat housing (just aside/behind the alternator is also a known issue, but where else?
My garage floor is covered with rubber mats and any fluids show up very well, but after a 200 mile drive I often need to add 0.5 liters of coolant to the expansion tank, but I cannot see any drops on the underneath of the chassis and no signs of any fluids on the rubber mats. The T-piece is not leaking, I have cleaned all the dirt from around the thermostat and will keep an eye to see if I see any coolant (there weren't any signs of coolant, but after 18 years there was a lot of dirt and it was damp, so could be coolant), but open to any suggestions/ideas. Hoping to get another 100+K miles from the old girl.
Thanks for all suggestions, I did add Bars Leak-stop about 500 miles ago, but it had no effect on the coolant loss (I didn't expect it to, I think the leak-stops are all voodoo and don't really work), but would welcome any suggestions, hoping it's not a head gasket as that is more work than I really want to do at the moment..
Gary
Gary
