AmandaWaymire
Just bought a new Forest River Wildwood XLite 28VBXL trailer, and a new 2021 Expedition Max with HD towing package.
RV dealer sold us (and installed for us) a Camco EZ-lift R6 weight distribution hitch (rated for tongue weight of 1000 lbs.).
We took trailer to CAT scales and weighed the Expedition alone, and the entire setup with AND without the WD hitch engaged:
Expedition:
Steer Axle: 3160
Drive Axle: 3220
Gross: 6380
With trailer (NO WD):
Steer Axle: 2720
Drive Axle: 4580
Trailer Axle: 5380
Gross: 12680
With trailer (WD):
Steer Axle: 2820
Drive Axle: 4440
Trailer Axle: 5420
Gross: 12680
As you can see, the WD hitch is only taking 140 lbs off the drive axle, leaving us above the axle's limit. We also installed Sumo springs on the expedition. We measured the sag of the expedition and the hitch manufacturer says it is installed correctly because we only have 1.75" of sag on the rear, but we measured after installing the sumo springs so I'm not sure if that impacted the measurement.
Should we take entire rig back to RV dealer and have them adjust the hitch? We can't make adjustments on it because we don't have the tools necessary to tighten to the correct tension.
Our tongue weight is acceptable, but it is right at 15% of the trailer weight, and I have read that it should be between 10-15%. How do we lessen it? Simply adding more weight or shuffling things around so more weight is in the rear of the trailer? I know we don't want too much, but I am thinking that if we can get it closer to 10% than 15%, that would also take some weight from the Drive axle... right?
I've been so stressed about this because we want to be as safe as possible, both of these vehicles were a big investment and because of our family size we couldn't do a pickup. RV and Ford dealer both assure us we're fine, but we've been running numbers and will feel better once we can get more weight off the rear axle.
Thanks for any help you can offer!
Expedition:
Steer Axle: 3160
Drive Axle: 3220
Gross: 6380
Steer Axle: 2720
Drive Axle: 4580
Trailer Axle: 5380
Gross: 12680
With trailer (WD):
Steer Axle: 2820
Drive Axle: 4440
Trailer Axle: 5420
Gross: 12680
