Cupholder fell through console! Weird!!!
StephenPT
Portland, OR
Do you have a picture of it? Nearly all connectors have some sort of a tab you need to either press with your finger/thumb or lift with a screw driver. There's a few connectors out there that have levers on them, but usually those are reserved for large bulkhead connectors.
Meeker
Calgary, AB, Canada
This one is one of the ones that has a lever. It's the lighter gray thing that wraps around 3 sides. It's stiff at first - you pull up on the part that has the "grip" lines if I remember right. The lever actually pries the connector apart (and pulls it together when you're reconnecting it). I don't have a picture that shows it however...
rob4092xx
Phoenix, AZ
Thanks to everyone who has helped me out. I want to order a new cup holder. Does anyone have a link or part number? Thanks so much!!!
FlyBry
Dallas, TX
Maybe this will help.
kylenobbe
st. louis
Same thing happened to my vehicle and the PremiumCARE warranty didn’t cover it. Dealer said 500 bucks to fix it, so will be checking out this forum to DIY it.
Not happy with this since I just bought this car, and have never heard of a car doing this!
rob4092xx
Phoenix, AZ
Once you make the repair can you please come back on here and explain how you unplugged the plug that goes into the Gear Shift selector? I cannot figure out how to disconnect it. Thanks!
kylenobbe
st. louis
I was able to put back on the nylon band as a temporary fix without disconnecting the gear shifter’s electric. However, the plastic welds are broken, which is the reason why the cup holder fell through. I plan on bolting the flange of the cup holder cilinder to the flange of the cup holder base. When I do that I will have to disconnect all the electric.
Anybody know of any problems that can happen if I disconnect the gear selector and 4wd selector?
MondayTX
TEXAS
You must be registered for see images attach
I did this repair today. The YouTube video below help me to get the center console trim piece off. I had the same issue as poster above with the disconnecting the gear selector, so I unscrewed the four bolts that hold the shifter assembly to the piece, then I was able to remove the trim piece and then unscrew the cup holder frame from the trim piece. Having the trim piece off is definitely the easiest way to put everything back together and I was also able to do the zip ties to connect the bottom/flapper piece to the cup holder “frame”.
Some pics…
kylenobbe
st. louis
Just fixed mine as well. I never ended up unplugging the shift selector and 2wd-4wd selector. I just unscrewed the 6 torx-head screws to pull the cup holder out similar to MondayTX (thanks for the tip).
We drilled new holes over the existing plastic welds and bolted the the flanges together with a little thread-glue to help it hold. The solution is better than the original design and will last forever. Thanks to my father in law for the idea
