CV Joint or Bearing? 2017 EL.
Alliance
Indiana
Replaced both IWEs and have checked for vacuum leaks (perfect long-term vacuum). Have what sounds like a partially engaged IWE that changes proportionally with speed, originating from LEFT FRONT. IWEs are not engaged in 2WD and are solidly engaged in 4WD, when checked idling on jack stands. Makes noise in 2WD and in 4WD (auto and high) modes. Differential fluid is full and clean. Noise momentarily QUITS when making turns to the LEFT at speed. Noise returns when turn lessens. 231k miles on truck. No clunk sounds when placed in drive or reverse. Bearing grease looked good when IWEs were replaced. CV Joint, bearing, diff gears? Any advice? TIA.
16exped
KS
Jack the front of the vehicle up and place on jack stands. Then grab front tire at 12 and 6 o’clock and attempt to wiggle, then check at 3 and 9 o’clock. If there’s “play” at the 12/6 position it’s most likely a wheel bearing, if there’s “play” at the 3/9 position it’s a tie rod end(or some other steering component)
PLEASE BE CAREFUL! I have had a whole wheel, bearing, disk brake, and caliper come off on me during a test. Thankfully it wasn’t on the road with the person that somehow managed to drive their vehicle to my house.
Suspension is the one thing I’m good with.
16exped
KS
Also when was the last time any of the front end parts have been replaced or inspected?
A
Alliance
Indiana
The front was up on jacks this past weekend when I was checking the vacuum lines and performance of the IWEs. There is no 'play' in any orientation. The vehicle was aligned 6 months ago with no worn steering components. Normal tire wear at all 4 corners.
The fact that the sound disappears entirely when making a left hand turn at highway speeds, which leads me to think the centrifugal force is fully disengaging the front left IWE. Again there is no vacuum leak in any portion of the system. The noise is consistent when driving straight, turning right, or turning left (at slower speeds). Does this help point to anything?
A
Alliance
Indiana
Replaced the vacuum check valve even though the vacuum test indicated no leaks.
Replaced the left front wheel bearing.
Checked the front diff fluid level - full, clean and clear.
Topped off the transfer case fluid.
The noise still exists except when making left hand turns (noise vanishes entirely).
Ideas????
16exped
KS
Any “play” with the CV axle? Does it make the noise in 4wd or just 2wd? Not on jack stands, if at all possible drive it in 4wd on the street.
