RKB713
I recently purchased my 2009 Expedition EL 4x4. On a test drive motor seemed sluggish so I checked codes and found they had reset battery ( as usual ) but the VCT / phaze codes were pending. Looking under hood appeared to be new valve covers, few non oem zip ties, and new VCT sensors. I was concerned that it could be the timing mess the 5.4 are know for. Used car dealer said they would fix it before I bought. I can back 3 days later drove and was 90% better had a stumble on the 3/4 throttle transition. No codes pending. After driving a few days i noticed the start up exhaust fumes were rough, first 30 seconds or so as well as exhaust seemed slightly louder for same time ( weird). I broke out the trust code reader and found they disabled the O2 sensors some how.
Question, could disabling the O2' s trick the cam/ timing issue?
I want to enable them but am afraid the timing problems will return.
Next issue, The electric clutch fan, yes its electric to engage then standard clutch. I see it was only use 1-2 years then followed buy full electric. My A/C sucks, proper pressures when fan 100% which is almost never. I swapped to 2010 electric fans and universal fan controller, this helped the a/c a bit but now has codes for voltage and signal return. Does anyone know a way to use a resistor, or disable that option? I am considering a 2010 ecm as well.
Thank for the help
Btw Florida here, no emissions, plenty need for A/c
I will return with exact codes asap.
Thank for the help
