See if you have the aux relay box 1 at the front left of the engine compartment.
That round plug is for the air suspension compressor if I remember right. Did the Expy originally have air suspension and someone converted it to standard coil spring suspension? The other picture of the junction box is supposed to be daytime running lights relays. One is an ignition relay and one is a headlight relay. Because the DRL's are not on when the headlights are on, they have to put a headlight relay in there to control that function. Do your foglights come on with the ignition ON ? Do they come on when you just turn on your foglights at the headlight switch ?
