Does anyone know how to remove a 2015 dashboard?
rollinstone
Seattle
I don't know if this will work on the Expy...I haven't looked, but on my 1997 Explorer I cut a flap out of the bottom of the heater box under the glove box (pass side) with a Dremel disk, and got access to the actuator motor and blend door. The blend door simply dropped out...it was broken. The motor was OK when I tested it so all I had to do was stick a new blend door up into its slot (it snapped in), replaced the flap and taped it up. Total cost was about $17.
C
Indiana
I've read about the clockspring and understand your recommendation. I watched a video from a guy named SouthMainAuto and I think he's from Pennsylvania. He showed just how those clocksprings are wound and how they work. I will be sure to secure the steering wheel to the column.
star-art
Pacific Northwest
...on my 1997 Explorer ... the motor was OK when I tested it so all I had to do was stick a new blend door up into its slot...
I've heard about blend doors failing on really old models. But, the actuator itself is more typically at fault. Either the internal gears strip or the carbon traces wear out. The older designs had weak gears. To save money, they left out limit switches (which would have made the actuators reliable for the life of the vehicle). Instead, they programmed the damned things to "test" the limits from time to time which causes the gears to strip. I'm told this happens every so many ignition cycles.
After years of owners enduring this, Ford redesigned the units to have more robust gears. BUT, they still never installed limit switches! And, the upgraded gears don't help because now the newer units typically fail from crappy carbon traces (cheaply produced). These wear out as pickup wipers inside the unit repeatedly sweep from cold to hot and back again over time.
It all comes down to corner cutting and penny pinching -- in a $50 part that costs $1000 or more in labor to get at and replace. And, don't forget our trucks can have as many as THREE of these things installed.
Is anyone reading this an attorney?????????
