StibbyWonder
Hi guys, I just want to ask what I should check first. I’m having a weird door-ajar issue with my front passenger door.
What happens is that whenever I close the door, the dashboard still senses that the door is open, and the dome lights stay on even though the door is completely shut. But when I open the door, the “Door Ajar” warning disappears from the dashboard, as if the door is closed, even though it’s actually open.
I’ve tried searching everywhere for a solution. I already cleaned the area with WD-40, tried opening and closing the door multiple times, and followed whatever I could find on YouTube, but nothing worked.
So I’m asking for help. Has anyone experienced the same issue, and how did you fix it?
Is the door sensor possibly faulty? Or could this be an electrical issue, like a grounded wire? How can I check if there’s a grounding or wiring problem?
Any advice would be greatly appreciated. Thank you!
