If every time you drive your Expedition, all your thoughts turn to the worn out OE air suspension that should have been replaced a long time ago, but you really don't want to spend your hard-earned money on overpriced aftermarket air suspension components... Well, we are here to give you a helping hand and introduce our budget minded solution. Meet this Air Ditcher™ Coil Conversion Springs Kit, made by Unity Automotive to solve all your air suspension problems and to safe your time and money. This is an absolutely maintenance-free set, designed as a perfect match for the stock specifications of your Ford to make the installation process flawless and your driving enjoyable again. All applicable rubber components needed are included in a kit.
Unity® - Air Ditcher™ Coil Conversion Springs Kit at CARiD
* Perfect Fit For: 1997-2012 Ford Expedition;
* Professional Installation is recommended;
* Bolt-On Design;
* Front and Rear Kits are available;
Check out the full line of Unity Automotive suspension products at CARiD: http://www.carid.com/unity-automotive/
* Bolt-On Design;
