Ecoboost problems I'm encountering...
Keaton Taylor
Ashland, KY
So I have the thing I've posted about before that I believe to be an IWE Solenoid (bought the replacement, just need to put it on)
1. My engine isn't throwing any codes but is definitely idling rough and it seems like it's putting out more exhaust than it should. I have plugs and no one local had OEM boots but they're supposed to get delivered tomorrow.
2. The battery is reading 11.9v at rest and is very clearly causing hard starts. Easy fix - going to get a Motorcraft 850 CCA replacement today. No big deal.
3. Yesterday there was a new sound under the hood - in neutral I revved the engine and as the RPMs were winding down, there was a hum and clicking. The initial thought was this was just a turbo winding down but I haven't heard this before so I'm a touch concerned. When they replaced the turbo (wastegate issue) a bolt broke off and went into the exhaust (intake? I don't have the paperwork here with me and am only mildly handy) manifold so they had to remove that to get it out. I'm wondering if they jacked up the gasket when they did that.
4. Then going up the relatively steep hill we live on yesterday I got a low pitched light grinding sound in a low gear.
Super frustrated with the dealer who I bought this from. The next step is to make an appointment with the Ford dealership that just replaced my left hand Turbo for a wastegate issue and make them let me take the tech for a drive.
grdsman
Colorado Springs
If you get out while idling and listen to the engine, do you hear anything then? Or was it just that one time that you heard the sound after revving it?
Keaton Taylor
Keaton Taylor
Ashland, KY
I went and started it and it kind of sounds like a baseball card on the spokes of a bicycle wheel, loudest right around the underside near the driver's side door.
HawkX66
Semper Fi!
VA/MA
Something is sucking your battery dry. Ford criminally leaves the power ports (AKA cigarette lighter ports) connected directly to the battery at all times rather than switching them with the ignition.
-- Chuck
Criminally? Lol. Personally I like that they are hot all the time. I use them while the truck isn't running often. Maybe something is draining his battery and maybe it's a dead battery. Five years old. Usually mine last a lot longer, but not all batteries are created equal and you don't know the history of the battery.
HawkX66
Semper Fi!
VA/MA
I've got nothing plugged in and it's definitely the stock battery from 5 years ago.
Being it's a used vehicle and you're finding a few issues, I think I'd do a load test and try to figure out if there are any shorts that caused your battery to die sooner than it should.
I like that Ford leaves the outlets hot at all times. Can’t tell you how many times that’s been useful for charging my phone without having to leave the truck on or unsecured. It’s nice to be able to charge items inside and take your keys away with you when you go someplace.
Keaton Taylor
Keaton Taylor
Ashland, KY
Went and got an oil change - my service guy wasn’t in today.
Air filter was black. Oil needed to be changed. 120 point check my ass.
running some forum recommended fuel system cleaner from Chevron through her this week, then I’m going to check plugs and change boots next weekend. The clicking stopped after the expy was warmed up - I’m guessing it’s an exhaust leak based on that. No grinding or sloppy chain sounds as far as I could tell.
HawkX66
Semper Fi!
VA/MA
Sounds reasonable. My 07 had a cracked exhaust manifold and it would do the same thing. It would quiet down when it got hot and expanded. Eventually it got worse until I fixed it.
It could also be, and is probably more likely, that the oil started making it to where it needed to go when it warmed up. Especially if it got better after an oil change.
LokiWolf
Moderator
Richmond VA
I need details before I can give any opinion.
Year Truck, I know it is 15+, but what year?
What are your current miles?
The EB’s are known for ticking. It is pretty common when cold and is due to Direct Injection.
A video/audio recording of the sound would be GREAT.
Sounds like there are many maintenance issues that need to or have recently been resolved most of your issues could be caused by many combo’s of the issues you mentioned, like dirty air filter, low voltage in the battery...and others.
LokiWolf
Moderator
Richmond VA
Yeah, I have heard this on a couple of the 3.5TT first gens.
I have a good friend with a 16 XLT Expy, and his sounds exactly like that when cold. Hasn’t gotten worse since it started, about 30K ago. He bought it with 20K+, and now has over 50K. Several dealers have looked at it, with no solution.
Once it warms up, sound goes away.
gunner1416
