99WhiteC5Coupe
I Googled it after putting everything back together, and it turns out lots of F150 owners have had this same problem. Not many ecoboost expeditions rolling around so not as widespread of a reported issue.
I hope your change goes easier than mine, there is a tool specifically designed to remove the coil pack boot, it's like 30 bucks. You can diy it if you have a piece of thin walled aluminum or steel tubing slightly bigger than the ceramic of the spark plug. Sharpen the edges on the end and gently push it through the center of the boot and around the ceramic plug, then pull out and the boot comes with it.
I have a 2015 Expediton Limited 4x4 with the 3.5. It has 41,*** miles and I planned to change the plugs at 45,000 miles (with the air filter again).
Do the coil pack boots have to be removed? Should they be replaced? What is the special tool you spoke of? Any part number or reference number? Thank you.
