notamechanicbrad
I pull a trailer daily with this Expy. The truck has 240k miles on it but has run good with no issues for the last 60k. It burns about 1 quart of oil every 2000 miles and I have to add 12-16oz of water/anti-freeze about once a month (about every 1000-1500 miles). Battery is about 2 1/2 years old (Platinum gel battery) and I do have to jumpstart it if it sits for 1-2 days, so I am guessing something is drawing a small amount of electricity when parked.
1 thing I did notice recently was the water in my radiator has a RED tint to it. I do not know if they topped off my fluids at my last oil change with some red anti-freeze. Thoughts were that possibly the radiator and transmission cooler had a pinhole leak between them. I have been monitoring the water and it doesn't appear to be getting any more red or higher or lower level and I haven't had any problems with shifting gears, etc...
This week I was driving from Dallas to Austin, about a 3 hour drive, and when I exited the highway the truck died. It started right up but I had to start feathering the gas pedal to keep it running. From that moment forward it has not maintained idle without me keeping my foot on the gas. I drove it for about 5 more hours, mostly highway miles (no problems at higher RPMs). No check engine light. It always starts right up but will immediately start sputtering and die. This happens when cold or hot. I've had 2 times I stopped and it continued running for a couple minutes before it died. The RPMs are jumping around between 250 and 750 when it is TRYING to idle.
I unplugged the VTC sensors (1 on each side of the front of the engine) and started the truck and it had no improvement. So, I have plugged those back in.
I have purchased but not installed or tested:
Blown head gasket detector kit
Throttle body
Mass air flow sensor
Coil packs and plugs
Idle speed control valve (Im not sure this truck uses this but read somewhere that may be the issue)
I have in my Cart but not purchased:
Fuel pump
Fuel filter
Throttle body
Fuel pump
Fuel filter
