Engine overheating only while parked and idling.
Discussion in '3rd Gen - 2007 - 2017' started by Michman, May 20, 2019.
  1. Michman
    Michman New Member
    39
    May 20, 2019
    Recently had a steering fluid leak at upper hose next to radiator, not sure if this causing trouble, but steering fluid went everywhere. Then a couple months later engine started to overheat while idling for extended periods. Once driving temps go back down in pretty short order, like within couple minutes. Replaced thermostat and still having the problem. Checked fuses today and both electric fan fuses were blown. Inspecting the electrical connections at the fans and they seem covered in black liquidy crap, possibly steering fluid. Would I just swap out whole fan assembly? Or test it for functionality? Possibly something else?
  2. stamp11127
    stamp11127 Super Moderator Staff Member
    61
    5,906
    1,088
    Mar 10, 2012
    Temple, Georgia
    Test the fans and connector for power before replacing them.
    Don Hall likes this.
  3. Michman
    Michman New Member
    39
    May 20, 2019
    Okeedokee. I’ll start there. I replaced the fuses already but haven’t seen the fans running yet.
  4. purevw
    purevw Member
    60
    20
    13
    Dec 26, 2016
    As electric motors age, they start drawing more current than when new. I imagine that the power steering fluid didn't help much. The fuses were blown. Barring a short, that likely indicates that the motors are drawing much more current than they should. If that is the case, replacement is the only real option. Before you run out and buy them, I would break apart the Molex connector and visually inspect the contacts. That connector may also need replacement. On my old Grand Marquis, the fan had drawn so much current that the contacts in the Molex plug were badly burned and the plastic housing partly melted. When the new fan was installed, it would not run 100% of the times needed because of the less than perfect connection.
  5. purevw
    purevw Member
    60
    20
    13
    Dec 26, 2016
    Run the A/C on high. That should cause the fans to start in a short time, whether the engine is warm or not.
  6. jon javedas
    jon javedas New Member
    63
    Jan 17, 2019
    Oakland
    If your fan at low and high speed,after t-stat opens,ac on high etc.. make sure p.s. fluid didn't spray all over the rad.
    causing the the cooling fins to plug up w/dust and dirt. easy remedy is some sort of h.d. degreaser(castrol makes a good product,its purple) spray on let set for a while,do this when its cooled down, and rinse w/plane water and garden hose and rinse from the opposite direction of airflow. Just a thought.
  7. Michman
    Michman New Member
    39
    May 20, 2019
    Thank you for the reply! I’m slow to get this remedied as I dislocated my shoulder and have not been able to do anything at all. Really quite terrible. I will do the a/c test as that won’t require any shoulder work. Appreciate the thoughts you had about my truck. Will also be getting some assist to swap out ignition coils and spark plugs as those have started going as well.
Share This Page
