Expedition front suspension
dragsten56
Bullhead city az
Just curious is it the same suspension on the front of my 98 expedition eddie baur as on a f150 because it will make finding my front suspension easier then having to fabricate control arms because I hate using the torsion key and lift spacers
2020FordRaptor
Nevada
I would think so but not 100% sure. Check the part numbers.
D
dragsten56
Bullhead city az
Thanks will do I have a idea for my overland rig I'm wanting to convert my rear end to a standard f150 style suspension so I have more options know anyone who has done it before
Dimz
COS
No, not the same. Sounds like you saw the coil suspension on a 4.6L and you want to put that into a tortion bar Eddie Bauer 5.4L. :) you probably could if you are an excellent fabricator, cause if you mess up any angles it won't steer right, nor is that coil set up rated for a heavier 5.4L. Question is it it worth it?
