F150 Tremor Wheels - Will they fit Expedition Max?
BlackBetty
Army
Surprise, AZ
Did the same mod on my 2016 EL to fit F-150 wheels as well. There will be approximately 1/2 to 1 inch of axle thread protruding through the center of the wheel. Thus, preventing you from installing the center cap. So, breakout some protective eyewear, and a pneumatic cut-off wheel. Good luck.
rqh12000
idaho
Yes, they will fit fine. I did it on my 2024. The rear half shafts do stick out ever so slightly, maybe an 1/8-in. I did Wood someone else had suggested on here of separating the Ford emblem off the center cap raising it up an 8 inch with double sided tape then re-sticking it to the center cap and run a bit of silicone around the outer circumference gap. You can’t tell that the rear center caps have been modified at all
rqh12000
idaho
Yes, they will fit fine. I did it on my 2024. The rear half shafts do stick out ever so slightly, maybe an 1/8-in. I did what l someone else had suggested on here of separating the Ford emblem off the center cap raising it up an 1/8th-inch with double sided tape then re-sticking it to the center cap and run a bead of silicone around the outer circumference gap. You can’t tell that the rear center caps have been modified at all. Not the best picture, but all I got at the moment.
hanisba
