A week after I bought a used '24 Expy Stealth with 43k on clock I floored it to pass a vehicle. The engine almost immediately ran rough so I backed off. The "check engine light" came on. It turned off maybe 2 or 3 minutes later, and then ran fine. I called the dealership to report it.
I tried it again 15 minutes later with the same results.
I went to a Ford dealership and they very nicely hooked up their scanner and reported an issue with cylinder #3. I honestly can't recall his complete explanation, but he did mention vacuum.
I checked today, 2 weeks later, same results.
Here's the question- is there a way to check the history of this vehicle to see if this code was tripped prior to my buying it? If so, should the dealership cover it?
