For Those Looking for a 3rd Gen Radio Upgrade
eddytheexpy
Phoenix, AZ
ok so I've wanted to upgrade my radio for a while and finally pulled the trigger after verifying I didn't nuke the engine while performing the timing job. I was weighing lots of pros and cons for various aftermarket setups. What I found was the usual, if you want it to be an easy install with good instructions while having expectations of a good outcome you just have to set your wallet on fire. I know some guys on here really lean into that sort of stuff but I tend to prioritize my mortgage over most things (that's why I own a 14 year old rig). So for those of you looking to reduce costs on this venture, search no further!
I purchased this radio: https://www.walmart.com/ip/9-Androi...7?wmlspartner=wlpa&selectedSellerId=101189037
this reducer (story below): https://www.amazon.com/dp/B00200K1X4?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
this dual usb port bezel: https://www.amazon.com/dp/B0BDWVB4T9?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
all-in-all ~$200
to get this result:
absolutely worth the money! Also, with the extra port in the face plate and a little bit of help from a file, I was able to repurpose the left one for my light bar switch. I love how the top row of buttons are shifted downward separating the digital components from analogue. Also, its super easy to program the steering wheel buttons to this unit.
You need the 12v to 5v reducer because the wake up signal for the subs makes them thump every time you turn on the vehicle. After the reducer is wired in, it no longer thumps on start-up but they do thump when the radio is connected to the battery (i.e. plugging in the wire harness after splicing in the reducer). Aside from that, I never heard the pop again and verified the function of the subs. I HIGHLY recommend not throwing out your factory harness until this set-up is finalized. I threw mine out and a week later did the research to figure out that I needed the reducer. The new harness has different colored wires so if you go my route, you'll have to dig up the pin-outs of these obscure connectors and cross your fingers that you found the right documentation when you start splicing.
The only drawbacks from this set-up:
1) this HUD charges your phone incredibly poorly when using wired connection instead of bluetooth for car play (the drive from San Diego to Phoenix only added 2% of charge)
2) there is about a 1-2 second delay between media audio output from the commands on your phone. Oddly enough, that lag doesn't happen for hands-free phone calls so it's really not a big deal.
3) There is an unbelievable glare off the screen if the sun catches it right. I'm trying to decide on an anti-glare film at the moment so expect to need that if you don't enjoy being blinded.
Anyway, I haven't seen any cost effective aftermarket radio set-ups talked about on this forum so I figured I'd put this on display for other like minded people. Hope it helps some people make the decision to bring their rigs into the modern age!
reklaw
Glen Rock, PA
I posted a picture of my Alpine Halo install from 2 years ago. Seems like your install might have been less expensive.
eddytheexpy
eddytheexpy
Phoenix, AZ
Woah $1400?! Yeah, no way I’d cough that up! That’s about how much the timing job cost me using genuine ford parts!
You ever figure out how to rig up the factory reverse camera? I haven’t moved the wiring so I just get a black screen when in reverse and it still displays in the rear-view mirror. Not sure if I care enough to re-wire it since it’s not really an inconvenience. If it’s easy I’ll probably give it a shot but if I have to get creative I’m happy leaving it how it is.
JayB66
Aurora, CO
Similar issues, but not the same either. My 09 XLT didn't have audio controls on the steering wheel. Since the wheel was in sad shape, I bought one new that had the controls. That wasn't enough to make the connection to the radio. I got different stories from Ford and my audio installer. Ford said the body control module might not have the connections(?) for the wheel controls. My installer said I probably need a different spring... Not sure which way to jump...
Shinerbokdoc
San Antonio
Hey guys,
Both of those are super clean, BRAVO!
I am very interested in upgrading the head unit/screen on my wifes ride (2014 Expy EL Limited 4x4) since the OEM unit is glitching and only allows 2 touches of the screen before it freezes up.
The head unit buttons still work and so does the steering radio controls, but the NAV screen is stuck where it lands after the 2 touches.
Any advice or updates to having your set up for almost a year? @eddytheexpy and @JayB66
eddytheexpy
eddytheexpy
Phoenix, AZ
Hey guys,
@Shinerbokdoc thanks for the shout out! As for the ~1 year update, everything is still going perfectly with it! TBH I was a little on edge about the cheap-o head unit since a lot of reviews for the various cheap ones on amazon said they started smoking after a while and living in Phoenix doesn't create a nice interior environment during the summer.
The only thing I've done to it since the initial post was add an anti-glare screen protector on it because the screen was incredibly reflective, which I mentioned I might do in my original post. Since this is a random/oddly shaped screen as it tapers towards the bottom, there was no ready to use product for it. I just compared iPad screen sizes to the size of the head unit's screen then bought an anti-glare film screen protector for whatever size iPad is bigger than the head unit's screen and carefully cut it to size. Came out looking like a factory-made product, even my fiancé complimented me on it which is a big deal because her response to me doing the entire timing job was: "Good job, you didn't break it. Can I start parking my car in the garage again?" hahaha
I guess the only advice I have to give besides what I've already mentioned is to be SUPER careful when removing the 2 top sets of buttons out of the stock facia. IIRC, the screws holding it in place also hold the buttons in place within each unit. If the button falls out, there's these 2 little pieces of plastic that act as the spring to push the button back out when pressed. Those pieces of plastic are just resting in there behind the button so they'll fall out too and their orientation/placement is not intuitive at all. I had to take the other side apart to compare and of course 2 of the 3 buttons in that one fell apart too. Luckily, I managed to keep one button intact which allowed me to reconstruct the other 5.
I always lean towards lowering costs and being thrifty so I highly recommend taking a similar route since this ran me a total of about $225. The install was maybe a 4/10 difficulty and if you leverage my lessons learned, that should crank it back to a 1/10 difficulty or 2/10 if you don't know how to solder (which is necessary to wire in the 12V to 5V reducer properly).
Let us know what you wind up doing and feel free to message me if you run into trouble with things!
