Calidad
Ok so first drive back home observation. Outside temps are 20 degrees warmer. Transmission temperature was 10 degrees cooler than the trip into the dealer this morning in cooler temperatures.
No fan running after the short climb up to my house like previously. Also the start/stop feature which was oddly mia for the past two months is now back guessing that the temps were just high enough to cause the start stop feature to balk at shutting down at lights.
The tech note says he drove it and head temps matched some other temp 97-103 which doesn’t mean anything given the transmission heat exchanger temps are clearly 10 degrees lower in warmer temperatures, more traffic and going up hill vs this morning which was zero traffic down hill in cooler temperatures trans temp was 212-214 vs after in worse conditions 192-194.
Inconsistent thermostat opening definitely a big factor in higher temps especially under load which I’ll test out again in a few weeks when I’m back hauling stuff
