ynpmoose
My factory brake controller literally went up in smoke 1500 miles away from home. I replaced it with a Tekonska P3, but now need to turn off the factory controller codes because I get a brake controller failure on the dash every time I start up.
I found the enable codes, 8 and 4 respectively. Is disable 0??? I've seen some conflicting info out there that as-built without a controller could be other numbers.
Trailer Brake Controller - Activate (if installing a factory brake controller) IPC 720-07-01 xxxx x8xx xxxx Change to 8 to Activate factory brake controller
Trailer Brake Controller - Gain Activate (if installing a factory brake controller) IPC 720-04-01 xx4x xxxx xxxx Change to 4 to Activate Gain display in IPC
