Don Hall
2004 4.6 18500 miles.
I'm crippled, so I'm just looking for help prior to going to a shop. I can only view the engine bay.
On a flat surface, no noise. Entering/leaving from a slight dip in the road, I hear a rubbing sound that disapates immediately when returning to a flat surface. Noise seems to come from right front area. It is not a quiet noise. It is a loud scrapping noise.
Noise sounds like rubbing/scrapping in the wheel well, abrasion with the ground, abrasion with a brake rotor, or a faulty shock. If you are familiar with Corvettes, they have an air dam to direct air up through the radiator. If you enter a road dip, the dam, which rides very low, will contact the road. This scrapping noise is similar to the Corvette noise, but the XP doesn't have an air dam.
At first, I thought maybe a safety cone became lodged in the suspension, or any heavy piece of trash.
Not sure what a faulty shock absorber sounds like.
I know some will advise to just stay on a flat surface, others will rightly suggest to pull
all trash from lower front suspension.
Hoping anyone familiar with the '04 XP suspension may shed some light.
Thanks in advance.
Thanks in advance.
