zfifty
I recently replaced (throwing parts at a problem) what I believe to be the original fuel pump in my 2000 Expedition (Blackie). Purchased from Advance Auto Parts. It was the Carquest brand. The main thing I did not like about it was the power connector on the replacement Carquest pump did not match the power connector on the original pump. The picture on the website for the Carquest pump, as you can see below, shows an adapter to use with a connector on both ends. Problem was they did not give me that adapter but a pigtail instead with a connector only on one end and 2 butt connectors. This required me to cut the original connector off my harness and crimp on the two wires on pigtail with the butt connectors. The wire colors did not match up to the harness. I am hoping it did not matter which way they went. I can't remember if I tried it out on the battery beforehand to check correct polarity or if I had power at the harness at the time to check. Anyway if I had to do over again I would not have accepted it as received as a pigtail. So others know, please check that the adapter is included, if purchasing a fuel pump.
Anyhow, I replaced the pump due to a no start condition, which went away and returned, assuming that was the problem, before troubleshooting to be certain. In other words don't follow my lead. Anyway I have other issues as this was not the fix, no fire (removed and grounded plug to check for spark), no fuel (fuel pressure gauge) and now have replaced the cam and crank sensors to no avail. All the fuses and relays check out and the fuel cutoff switch is good. I could not communicate at first with the PCM. I had to reset security system ( for some reason it was alarmed though not originally) and then was able to communicate with the PCM but had no codes present. The battery had been unhooked and may have reset the codes. Still no fire/fuel condition. No physical damage to my PCM inside or out.
I have sent my PCM off to get it checked out and repaired hoping to hear the analysis soon. Will update when I do. Sorry for all the rambling.
