Fuel pump replacement
Discussion in '1st Gen - 1997 - 2002' started by kdmentze, Dec 9, 2016.
  1. tcwaltz
    tcwaltz Full Access Members
    200
    44
    Jun 20, 2016
    Niceville, FL
    The tank may not spark but the sheet metal he's cutting above can.
  2. Boose
    Boose 2017 Platinum EL
    273
    86
    Mar 18, 2014
    NJ
    This is not an area where I'd recommend cutting corners. How many fuel pumps do you plan on adding to the truck? replace with a quality unit and it'll last for 10 years.
  3. 1955moose
    1955moose Full Access Members
    5,933
    1,272
    Nov 23, 2014
    I agree, buy either a Ford part if still available. Or at least one of the top ones available. Mine is 16 years plus. Unless you plan on keeping your SUV another 15 years, why bother with all the cutting. Siphon off fuel, if too high or heavy, and just drop tank. Total time shouldn't be more than a couple hours. Why chance cutting the hole, then you'd have to smooth out metal, to keep from cutting yourself on sharp metal, Good luck, let us know if it fixed your problem.
  4. rollinstone
    rollinstone Full Access Members
    106
    20
    Mar 26, 2014
    Seattle
    I had to have my shop do it...cost was about $960 parts and labor...yuk! Shoulda taken a chance to blow myself up.
  5. 1955moose
    5,933
    1,272
    Nov 23, 2014
    Well look at the bright side, you didn't spill any fuel on yourself. Sometimes in life we have to allocate our time. Work and the family come first. Their will be other projects on your SUV that you can share with the kids.
  6. Ale5jandro01
    Ale5jandro01 New Member
    41
    Sep 8, 2016
    US
    Just did the gas pump and filter replacement with a mechanic. 900 bucks!
    Expy 2007. Motorcraft parts. South California. The expy left me stranded in the middle of the freeway on saturday :(
    Sent from my SM-N950F using Tapatalk
  7. Boose
    273
    86
    Mar 18, 2014
    NJ
    a grand for a fuel pump replacement... that's just nuts...
  8. 1955moose
    5,933
    1,272
    Nov 23, 2014
    Not really. Southern California labor prices are about $150.00 an hour, $175.00 to $200.00 at dealer. The Ford pump is over $300.00 by itself. $600.00 for labor at a quality shop in California is possible. Four hours labor to diagnose and replace pump, isn't that crazy, I've heard of a lot crazier here.
  9. Boose
    273
    86
    Mar 18, 2014
    NJ
    it is what it is... just glad I do my own wrenching.
  10. TobyU
    TobyU Full Access Members
    1,316
    472
    Apr 5, 2013
    Ohio
    I cut a three sided panel on a 2001 Yukon about 3 years ago and did one. Not that much easier than pulling tank really since you have to pull the seat out and that is like 6 bolts. THe carpet just flipped back though.
    Just bend it back down into place when finished and put some caulk around it.
Share This Page
