1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Fuse/ short issue
Discussion in 'Electrical' started by Florida Roy, May 27, 2021.
  1. Florida Roy
    Florida Roy New Member
    52
    May 27, 2021
    Phoenix
    Ok, I am in need of some Help here. The previous owner of my 1999 Expedition bypassed the Windshield wiper with a toggle switch. Wired from the fuse box with an inline fuse on it. The wire came off the post of the switch and shorted. My radio, all my dash "idiot" lights, and the navigation info that is on the ceiling in front of the mirror all went out. I pulled all the fuses and visually checked them and they all look good to the eye. The inline fuse he installed is 30amp. It did not blow. Is there a specific place/fuse/relay that I can check? All my running lights and blinkers work. It's just those interior components that went out. I heard it when it shorted and saw all the lights go out when it did. Can the fuses be blown and still look good? I really need to fix this problem as I have a 3 year old daughter that I cannot drive around Phoenix with the windows stuck down. Any help would be greatly appreciated. Thank you
  2. Aspen03
    Aspen03 Full Access Members
    635
    296
    Apr 24, 2019
    Indianapolis
    Typically a blown fuse stands out visually but not always. If you are unsure invest in a multimeter and probe suspected fuses. It's a quick job and is more accurate than the eye. Nothing fancy needed, just a basic one though nicer models w extra features may come in handy down the road if budget permits.
    riphip and Florida Roy like this.
  3. JamaicaJoe
    JamaicaJoe Full Access Members
    67
    286
    117
    Dec 20, 2020
    Oviedo FL
    I would start by tracking down where that 30 amp circuit got its feed. In addition to open fuses, Look for any toasted wires nearby. A multimeter with a needle instead of a digital display is easier and more trustworthy device to troubleshoot vehicle electrical systems.
    It appears the original owner intended to "fix" excess current draw from a bad wiper motor. The rear wiper is famous for draining the battery.
    I would try to put the vehicle back into stock condition even if you need to replace a wiper motor. Otherwise you have a fire hazard kludge,
    Sent from my SM-T350 using Tapatalk
Share This Page
