Hello everyone!
Wondering if anybody has experience in piggybacking accessory (dashcam, radar detector, etc) into the interior fuse box?
I used voltmeter to find a fuse which is not powered without ignition, and so far found only fuse-37 (Heated steering wheel). All others seem to be powered, even after some time (checked two hours after ignition off). The issue with Fuse-37 is its position, I cannot insert a fuse-tap all the way down and keep correct load/draw orientation. Loose connection kind of bothering me, considering that I use external dashcam battery pack which draws 9A during the charge and has 20A fuse itself, plus 20A heated steering wheel - so need a solid connection for potential high current.
I suspect there could be timeouts before some circuits goes down, but couldn't find any information about that.
Would appreciate if you share your experience or theoretical knowledge.
Thanks.
Thanks.
