Growling noise and shake at 70+ mph
3510r80
Wisconsin
Hi everyone! This is my first post on this forum, and also my first time owning an expedition. Back in January I purchased a 2019 expedition limited with 143k miles. I am now at 155k. I did get this truck for relatively cheap since I knew it at least needed updated cam phasers installed at the time of purchase, as well as new tires (they were mismatched). Initially after paying a local shop to fix those issues (along with some other minor things, including alignment and balance of my brand new Michelin defenders), the truck was great. And overall I've been super happy with it over the last 10 thousand miles. However...
Overtime, the truck has developed this buzzy vibration in the floor and steering wheel that is especially noticeable on a smooth road at 70+ mph. This is accompanied by a low growl coming from somewhere underneath the truck. If I put it in 4A, the noise and vibration gets significantly worse, but even in 2wd the vibration is bad enough to make my foot feel like its falling asleep on the gas pedal. So, I took it to my local shop and had it looked at. They put it on a lift and determined that my front right wheel bearing was noisy. They also said they noticed that the vibrations go away when turning side to side. Anyway, I authorized a new wheel bearing and the shop said they thought it was quieter afterward. $709 later (part of this cost was from them taking apart and inspecting the front differential, which they said looked fine) I take the truck for a drive and it sounds EXACTLY the same. No noticeable difference. The 2015 ford edge loaner they gave me to drive was smooth as butter all they way through 80 mph. Zero vibrations or shakes. My parents 2022 expedition max is also super smooth. Meanwhile mine feels and sounds like I have big aggressive mudders on it.
I currently have my truck back but this vibration is driving me insane, and I feel like the money I spent was wasted. The shop gave me a quote to take off the front driveshaft and inspect the differential bearings. I'm struggling to see how turning side to side could affect the noise if it was coming from the differential bearings. I guess I'm just wondering if anyone can point me in the right direction here? I know there are lots of threads on the expedition and f-150 forums about this, but most of them seem to be wheel and tire problems. My tires were just rotated so I don't believe it is that. Thanks in advance everyone!
Update 10/10/26: I replaced the drivers side hub assembly myself. Vibration and noise is still present. I took a 50 mile drive to test it out and noticed that at one point on the highway, the vibration just... stopped. Ubruptly. I was just cruising at 80-90 mph and didn't change anything, but I noticed right away.
Update 10/15/26: Took it back to the shop and had them look at the truck on a lift. They said the front driveshaft was spinning a little even in 2wd mode, as I expected. This is from some internal friction in the transfercase and is normal on a 4A system. They then removed the front driveshaft. I have yet to drive it but they confidently told me that now, when the front IWEs disengage, the noise goes away completely. They quoted me 1700 installed for a used front differential. I'm going to pick up the truck and drive it without a front driveshaft for the weekend before I do anything else.
Update 10/15/26 x2: The noise is gone! I can clearly hear and feel it for the first half mile after engine start, and then it goes completely silent. I will be getting my front differential replaced next week, and I believe that will fix it.
akras
PA
Did YOU (not THEM) notice the sound changing when you turn? With bad bearings it's usually pretty obvious, and it usually doesn't take 70 mph to manifest itself. And it shouldn't be affected by going to 4A. I would consider a different shop, honestly.
Keep in mind that you may have more than one issue. Growling sounds to me like a bad differential (but I have no clue what you call growling, so who knows). Vibration in the steering wheel at 70 mph is most likely a problem with wheel(s)/tire(s). Rotating them means nothing if more than one is bad or if swapped left/right front tires. Find a good show, and let them have a look.
3510r80
3510r80
Wisconsin
Thanks for the reply! The noise doesn't really change when I'm turning like a wheel bearing would. It seems like maybe its a tiny bit quieter when I'm turning side to side but that could just be down to higher tire noise drowning out everything else. I CAN tell that there is a vibration/noise at anything over like 35-40 mph, but I tell people highway speed because they are more likely to notice. Its definitely the worst on a perfectly smooth road at 80 mph, its seriously terrible and it irritates me that nobody else seems to be able to feel a significant issue.
I'd normally agree with you that it is probably tires, but not only are they less than a year old, I have actually had them road force balanced twice now. The vibration I'm feeling is perfectly in tune with the noise I hear, if that makes sense. The "vibes" are all happening in sync and I have never heard an out of balance tire sound this way. I am dropping the truck off again tonight and tomorrow I am having the shop remove my front drive shaft. Apparently with this particular transfer case design (4a/2spd) the residual oil flow can make the front shaft turn even if it is not engaged. That would explain the noise being present in 2wd but louder in 4a. I will update tomorrow.
GlennSullivan
NY & FL
Has someone checked and confirmed that all 3 shafts (shaft driving into front differential and 2 shafts driving the front wheels are not turning at all during normal 2 wheel drive operation, having any of those not-disengage can certainly cause vibration.
3510r80
3510r80
Wisconsin
That's a good question, I should have them check that. However it is my understanding that with the torque on demand system, the residual oil sloshing around can cause the front differential to turn a little bit even if the clutch isn't engaged. I wonder if that is true? Kinda hard to say without putting a camera under there and looking at it when driving.
GlennSullivan
NY & FL
Decent res cameras are cheap enough these days to do exactly that. Get an inexpensive PTZ unit and velcro it underneath and power via a long USB cable to a port in the truck. I would not attempt it with the suspension unloaded on a lift or jack stands.
3510r80
3510r80
Wisconsin
Update posted in original comment. I'm trying to keep things organized and simple for people like me having this issue down the road.
Al_Harley
