Connection to the MS CAN Network is required so that you can integrate the Heated Steering Wheel into the modules required to control the HSW function.
To make it easier to connect the wire harness to the MS +/- Network, I removed the two screws holding the OBD connector under the dash. See pic below:
The OBD connector is on the bottom of the dash, just above your right leg when you are pushing on the brake. See Red Arrow.
Pull the OBD connector down to make it easier to access the connector and strip back the insulation wrap on the back side of the connector.
Yellow arrow points to the area where I placed the HSW module and zip tied it up out of the way. Recommend you wait to zip tie the HSW Module until all your connections/splices are made and you are ready to begin putting everything back together...this will give you a little flexibility to move the wire harness/HSWM slightly when making the connections.
NOTE: ensure you place the module in an area that won't affect/impact your steering wheel tilt/extend functions.
