17LimitedExpy
This is Connector C2280F (see red arrow) on the BCM:
As you are looking at the Module, the connector is located at the top right.
Disconnect the connector and remove the white plastic cover (it's held on by 4 plastic clips).
Peel back/cut the insulation wrap around the wire bundle to give you easier access to the wire that goes to pin 11...the wire is White & Blue in color.
Looking at the back of the connector you should see the pin numbers and then count over to pin 11...follow that wire back to an easy location to place your splice.
Splice your wire harness power wire to the wire that goes to pin 11. Use some electrical tape to rewrap the wire harness/splice area, reinstall the white plastic cover on the connector and reconnect C2280F to the BCM.
Reinstall the kick panel.
