99WhiteC5Coupe
Nope you lost the tube going to the IC, down low near the radiator. Pretty common. Should be an easy fix if you can get to the hose. It probably worked it way off due to oil/moisture in the tube. Hopefully the clamp is still there. If not you will need one. Fairly big. Can't remember the diameter.
I recently had the leaking engine water pump replaced on my 2015 Expedition Limited 4x4 at a local Ford dealer (only took four trips to diagnose).
Now, when I cold start my vehicle (20-45 degrees F ambient temperature), I also get one or two pops. I bought the vehicle new, and it has never been wrecked or damaged - or made this noise.
The technician damaged one large plastic intake piece, and it was also replaced under the repair - in addition to the water pump kit (Ford extended warranty).
Is the hose you mentioned going to the inter cooler (IC?) a rubber hose, or a hard plastic hose?
I’m very irritated with the dealer service and would prefer to try to fix the problem myself, instead of a fifth trip to the dealer. Any additional help would be appreciated.
Thank you.
