I'm trying to locate the fuel injection pressure sensor on my 08 Expedition. I bought the sensor, but can't find where it's mounted. Normally they would be mounted on the injection rail. Mine however just looks like the injectors are the only thing on the rail.
This sensor probably wont fix my ongoing problem but it won't hurt to try. The ongoing problem is strange. Basically if I floor it from a complete stop it takes off and goes fine. But if I roll away from a stop and then step on the gas it just doesn't accelerate. In fact the harder I step on the gas the worse it gets. It's acting like it isn't getting gas. Ive done a TON of work to try and figure it out. The engine runs perfectly smooth and quiet. As it's barely accelerating it will basically feel like I flipped a power switch around 4K rpm and suddenly it wants to accelerate. COP's and plugs are new, all cylinders are firing. The fuel pressure is great at idle but I don't know what it's doing while driving. The fuel pump/filter is new. O2 sensors and Cat converters are brand new. MAP sensor and air filter brand new. I performed a pressure cleaning on the injectors with the engine running for 10 minutes.
