Help! I just paid 2K for AC Repair have more Problems Now
Pasaune
Alabama
I have a 2007 Ford Expedition EL 5.4 with 194Kmiles. A couple of weeks ago I heard a loud rubbing sound and smelled burnt rubber and it immediately started blowing hot air from the AC.
I took it to a mechanic and he said the compressor went out. Later, he called and said the condenser is also bad.
I go to pick up the car today and immediately notice the air recycle door is no longer working and a red fluid all over the ground. They said they will fix the door and they forgot to cleanup the transmission fluid.
Now I have noticed there is no condensation under the vehicle after idling 30 min in 100 degrees. Also, the AC gets hotter when I am not moving. Also, the car idles at 1K RPM and it used to be more around 750. I paid 2K for a new compressor and condenser. What should I do?
S20Workstation4
Hyde Park, NY
I would take the vehicle to a different shop, preferably a shop that specializes in A/C Repair. Have the new shop check the pressure and ensure the correct amount of refrigerant is in the system.
A professional and reputable A/C Shop would find the cause and should also be able to tell you if you needed a new condenser & compressor.
The 5.4 3V specs, at HOT Idle, should be 600rpm in Park and between 500-550PM in Drive/Reverse. When the ambient temp is high (usually above 98 degrees Fahrenheit), the A/C system won't function correctly at the hot idle specs, so the PCM will automatically bump the idle up to a desired point. Is the car idling at 1k when the A/C is on, or off? Either way, the car should not have a hot idle of 1,000 rpm.
Check to make sure that the clutch fan is kicking on when the A/C is activated. Poor A/C performance when not moving, and proper performance while driving, may indicate the fan clutch is not properly engaging. The fan needs to be running to pull air through the condenser.
Hope this helps,
-Joseph
BigOleFordFan
Nope, notta, no way, 'Jose, not doin that !
They tell me I'm in PA, but I have my doubts...
This is about the same that my 011 EL does (also with a 5.4/3V Triton engine), so that would be a good place to start with the troubleshooting process, while will lead you to the clutch fan workie/no workie :D
Ice Tech 66
fort smith, Arkansas
Wow they seen you coming. I have 37 years of HVACR experience as a service tech. There is no way it should have cost that much. Wish you were around my area, I'd definitely help you out.
2010ELExpy4x4
California
Don't overlook the rear unit, we went round and round with our 2010. Charging would work for awhile, then would get warm. Every once in a while we smell what I can only describe as band-aid. Mechanic found small leak in rear evaporator caused by a combination of dust and moisture, corroded the aluminum, new one solved all issues.
