Help! Many warnings after Readylift 3/2 with CCD
FatherDH
Thousand Oaks, CA
Hi All,
(Edit - I fixed the problem I describe below. Turns out I damaged the driver side speed sensor during the lift install. Ran the codes and found that out. It was an easy $40 repair. Now everything works as it should!)
I'm hoping to find some help here in the forums.... I just lifted my 2021 Limited with the Readylift 3/2 kit with CCD. After the lift was installed I started getting many warnings popping up, which now makes the truck drive like hell.
Has anyone had this happen who has installed this lift?
Here are some of the errors popping up:
Hill Descent Control Fault
ABS Fault
Pre-collision assist not available
Hill Assist Warning
Limited Torque
(can no longer shift into 4wd)
LokiWolf
Super Moderator
Richmond VA
Sorry I missed this! Glad you got it! Looks good by the way!
HILLY
Greenville, SC
Glad to see that worked out for you. $40 fix is not bad and based on the date and time of the post, you were even able to get one on a Sunday!
