Hello! I took ownership of my father’s expedition last year and did a bunch of work to it getting back up to speed. It’s a 98 Expedition XLT 5.4L.
Short story, when I inherited the vehicle it had code P0171 on it and nothing else. A year later, it’s still the same after all of the repairs below. Note, P0174 has never popped up. The code is intermittent and once cleared, pops up again in a day or a month. It only happens while driving. Vehicle drives fine but you smell gas (sometimes when vehicle is turned off, only right after running). The only other I can think of is maybe the fuel injectors but I don’t know how to rule them out. My thought is maybe one or more are having problems with open/close. Connections are tight as well to all injectors (injectors are original). Any insight or help would be appreciated!
My dad also historically put good fuel injector cleaner in every 3,000 miles and is the original owner.
I have already replaced (mostly using OEM parts):
- Head Gasket
- Timing Chain
- Spark Plugs
- MAF (good brand) and Air Filter (less than 6 months ago)
- All Vacuum Lines (incl. PCV and throttle body rear line)
- Idle Control Valve
- Cleaned Throttle Body
- Replaced Throttle Controller
- Front (before CAT) 02 Sensor
- Evap Hose to canister
- Fuel pump replaced
- Fuel filter replaced
- Fuel neck hose
Only thing to note is exhaust is about six years old. Little bit of rust, no visible rot.
Any help would be appreciated!
- Head Gasket
- Timing Chain
- Spark Plugs
- Fuel neck hose
