Help with diagnosing wire
mattyates12
kentucky
Can anyone tell me what this wire is? I was changing the ignition switch and when I took the bottom cover on the steering wheel column off this wire was just hanging? Just has a little male prong coming off it. I can’t find where it plugs into? Any help would be greatly appreciated!
99Redcobra
MA
check for power in the wire. If no power it is probably the ground wire that lets it know the keys in the ignition and to chime when the drivers door is open. If you ground it, with the door open and it chimes, Im right. If not, Im not.
