Oh, where to begin but I will be brief. I should have pointed out in my first reply to your "get an Ecoboost" reply that you are one of those people that either doesn't read the OP or does read it but decides to post a reply that is not even relative to the OP.
It should have been obvious to anyone reading my OP that if I wanted to replace my "16 year old jalopy" I would not have spent the money to upgrade but would have replaced it. I don't want a ******** Ecoboost. So, unless you have some suggestions that are relative to my OP, post them. Otherwise go find someone else to bother.
To the Ignore list you go.
I built a Romeo block 4.6L for my sons 02 Mustang. His first car. Great little motor and easy to build. No idea on HP. I wasn't trying to go nuts with it. I have a 525hp/550tq big block that I run in my 69 Camaro though, so I do know how to build for power too.Planning to build such a motor for my '03Expy and want to collect any thoughts from forum members that may have experience with building up the 2V 4.6L motor.
My first thoughts was, of course, building a nearly stock motor and supercharging but I would only do that if there was a "bolt on" package and I have not been able to find one.
I would not rebuild the motor (160K) that is currently in the vehicle which has been mildly modified with under drive pulleys, electric fans, shorty headers, CAI and a 5 Star tune. I expect HP has been increased from 232 to 250-260; I can hold my own with my workmates later model F-150 EB 5.4L. So I am looking at picking up 100HP, naturally aspirated which I believe doable. Also added 4.10 gears and it moves out smartly but far from a barn burner.
Generally, the plan includes:
-overbore to establish a true bore; .010"-.020"
-increase CR from 9.4 to say 10
-have heads ported or go to aftermarket (one of the best head porters in the country is 45 minutes away and a good friend)
-new intake manifold (no idea what is available)
-mid duration cams, say 235*-240* intake and exhaust
-replace crank with something stronger (no idea what is available; have been told the OEM crank will hold up)
-retain CAI; maybe need to replace with something that flows more air??
-retain shorty headers (I know, full length would help but I don't want to get into modifying the exhaust)
-tune to pull it all together.
Plan B is go to aftermarket for crate motor and heads but haven't researched that option/cost/complications? yet.
Any suggestions from forum members are welcome but don't tell me to replace the 4.6L with a 5.4; not going down that road.
[QUOTE="...
What's my premise that you don't agree with? That it's a waste of time over boring for a "true bore" or my response to your question of what a "true bore" is?While I don't agree with Hawkx66's premise, he did prompt me to ask a question. In your OP, you said you would NOT rebuild the motor currently in the vehicle. a crate motor is Plan B, so I assume the "-overbore to establish a true bore; .010"-.020"" is Plan A. what motor would you be overboring?
jg
