Hey everyone! Travel trailer question..
JasonH
Houston, TX
I just picked up a 33' Grand Design trailer that we had to order because of low inventory. I wish we had towed it before we purchased it. It's a giant sail whenever a big truck passes by. You initially get pulled towards the truck and then pushed as it passes, so it's a bit unnerving. Keeping it under 60mph helps. I'm still dialing in the Blue Ox SwayPro hitch, but I think it's about right. I have very little squat. The tongue weight is around 650lbs and the trailer is close to 7,000lbs the way we have it loaded, so it's well within the towing and payload limits. There's just a lot of surface area that pushes and pulls on the back of the Expy. I might end up looking at an F-250, but I really don't want to give up the third row and the ability to park in the garage. Before this TT we rented a 29' that was closer to 6,000lbs and it towed a bit better. I think the length is the biggest issue.
It's normal with a half ton and a long trailer. I experience the same with my 33 ft, but adjusting the WDH helped, now I barely notice it. I am able to drive with one hand comfortably. Make sure tires are aired properly as well.
Squark
NC
I wanted to give an update from my last post after getting your feedback. I loaded more weight in the front of the trailer, lowered the hitch ball so it was level, and tightened the bars one more link on the Blue Ox hitch. We drove 100 miles yesterday and it was sooo much better. There was no sway and I didn’t get pushed around by trucks like I did previously. It was a much more relaxing drive.
Lesson learned: a properly set up hitch and a properly loaded trailer make all the difference.
RustyOval
Illinois
Can u advise what Sumo springs u bought. How well do they really help in your opinion
thanks
Here is a screen shot of the sumos I bought from etrailer. They remove some of (but not all) of the sag, doesnt really tow a whole lot different IMO. No affect on nontowing commutes/errands. I had some on my '09 so I did not hesitate on the '18. I think they are a great value for the money and istallation was a breeze.
LyoddChrissmiss
Cincinnati
Sumo’s just installed. Wasn’t too difficult at all. Just lifted the rear end to get all weight off coil overs and worked to Sumos on.
Haven’t towed yet but I’ll give an update on sag and how it handled (and yes I did clean my independent rear while down there)
LyoddChrissmiss
Cincinnati
After installing the Sumo Springs, I noticed a significant difference in the rear sag. (Pics Attached) I’d say it brought the rear up 1.5” when it’s loaded with my TT then before.
Pulls great too with everything leveled out.
Daily driving without any load truck sits stock height and I can’t tell they are on.
Best $169 I’ve spent on the Ex
flying68
Wichita, KS
Nice, I am assuming the before is with the WDH adjusted correctly. Did you notice any difference in handling or fuel economy?
LyoddChrissmiss
Cincinnati
WDH is the same before and aft. Yes I don’t have precise numbers but it seemed to get a little better gas mileage
