"Home Brewed" Transmission Fluid Flush
bring_em_on
MD
I've got a 2021 Limited with 75k miles on it that I bought new. I recently came to the fork in the road that I was either going to keep this Expy for several more years, or would trade it in on a new one. I like not having a payment so I decided to keep it. I wanted to play catch up on some neglected maintenance so I decided to completely change out all drive line fluids. I'm very consistent with engine oil changes at 3500 miles but have never really paid much attention to my transmissions. After reading up on the 10R80's, I decided to tackle the job myself. Front and rear differentials, along with the transfer case, were all pretty easy and straightforward (but the front differential required me to be a contortionist!). Anyway, i wanted to do more than a standard drain and fill. I wanted to "flush" it but not pay the dealer's nearly $500 to do it. So, here is what I did:
1. I purchased 14 quarts of the Valvoline full synthetic ULV. Good reputation, availability everywhere, reasonable price were all deciding factors in my choice.
2. Unscrewed the "dipstick" and used a hand operated vacuum pump to remove the approx 4.5 quarts of fluid in the pan. It was a very brownish red color so I know it was overdue. Not black or anything but degraded for sure. There were absolutely zero "flakes" or sparkly stuff so I know the internals are fine.
3. Used a hand pump to replace approximately the same amount I took out.
4. Started the Expy for a total of 30 seconds to get the fluid circulating. During this time, i shifted through all the gears.
5. I then pumped out the pan (4.5 quarts again). The fluid being pumped out was pretty much the same as the first draw so I know I circulated the new fluid up into the transmission.
6. Filled it back and repeated my 30 second engine run/gear shift procedure.
7. Again, drained pan. Fluid was more reddish than brown at this point so I know I'm still making an good impact on the fluid exchange.
8. Filled it again with 4.5 quarts.
9. Took it on a short road trip to get it up to operating temperature. I could already tell that the gear shifts were amazingly smooth.
10. At 200 degrees, I made sure I was parked on level ground and did the fluid level check. Nearly spot on but had to add about 1/2 quart to get it exact. When I pulled the dipstick, I could definitely tell that the fluid was very very clean. I dripped a few drops on a white paper towel and it was beautiful! I ended up using all 14 qts (well, probably a bit less as it was impossible to get every last drop out of the fluid bottle with the hand pump)
I had done a pre-fluid change temperature check while towing a 6000 lb load and I peaked at 219 degrees (ambient temp 83 degrees) with some gentle rolling hills at highway speeds. Post fluid change, I peaked at 208 degrees (90 degrees ambient temp) and that included a tow across a very steep bridge across the Potomac River. Needless to say, I am very pleased with this process. Temps are way better, shifts are extremely smooth, and it just feels better in general. I know I didn't get all of that old fluid out but I am willing to bet I got well over 90% of it. Not bad for less than $200 and a couple hours work. I would have spent that much time driving back and forth to the dealer!
Hope this helps you.
Boosted
North Jersey
Just to let you know the math, 13.1 quart capacity with 3 drain/fills with 4.5 each time = ~73% fluid change.
akras
PA
A good write-up, matches my experience, too. That's the way to do it. Keep in mind that you have actually replaced only about 70% of ATF, at best. So you may want to repeat after 20-30K. I ended up installing a PPE aluminum pan: it makes AFT change much easier and helps with cooling a bit.
Another thing: you may want to consider replacing thermostat. Old ones are known to stick and cause increased transmission temperature. My transmission temperatures went down by over 10F after I replaced my thermostat (a bigger effect than the aluminum pan).
akras
PA
Yep (a bit less, actually), but that's not necessarily a bad thing: it gives the adaptive control a chance to adjust without the need for a full reset.
bring_em_on
bring_em_on
MD
Thanks for the responses. I'm not sure I'm following on the math, though. The unknown is the amount of fresh fluid that gets ingested into the transmission during the 30 second run. Based on the results of the second and third drains, I'd say I was pretty close to matching the flow rate. Assuming I was fairly close, the math I am seeing is better than 73%. And based on the translucidity of the of final fluid, it matched the fresh fluid quite well. The Valvoline ULV is surprisingly light in color compared to most other fluids I have seen.
akras
PA
Round 1: 4.5qt out of 13.1qt replced. That is 4.5/13.1=0.34 replaced, or 0.66 (66%) of the old ATF left.
Assuming that everything got perfectly mixed in those 30 seconds, after the second round you will have 0.66*0.66=0.43 (43%) of the old ATF left; similarly, after the 3rd round, you have 0.66*0.66*0.66= 0.29 (29%) 0f the original ATF left, or 71% replaced.
That was assuming 100% mixing in those 30 seconds that you run the truck between rounds. If mixing was less than perfect, your actual replacement rate is lower than 71%. In reality, I doubt that you had anywhere close to 100% mixing, because otherwise those 29% of old ATF would noticeably affect the final color of your ATF, and it looks like it didn't. You can figure out if that was the case easily: check the color of ATF now, after you actually drove the truck. If it is noticeably darker than what you observed after round 3, you didn't have good mixing in those 30 seconds; if it's about the same, then you did.
bring_em_on
bring_em_on
MD
When I did the color check, it was after I had gotten it up to operating temperature. That was roughly after a 25 minute drive (i actually had to work it hard to get it up to 200 degrees). So that was what I was basing my guess on. I had seen some videos of guys doing a more complete flush on the 10R80 by disconnecting the cooler return line and dumping the fluid into a drain pan rather than the transmission pan. In a 30 second run, it was appearing that roughly a gallon of fluid was dumping into the drain pan. I know that's by no means scientific but it's a good baseline to measure against.
HILLY
Greenville, SC
I haven't done it yet but plan to, but on previous trucks I've done the method of disconnecting the cooler lines and letting the transmission pump out the old into a container and using an electric pump to add new fluid into the return line. Usually would be 2 quarts out, two pumped back in. Rinse and repeat like you did. Gets a lot of the old out especially what's sitting in the torque convertor. Also a good method to drain prior to dropping the pan (when there isn't a drain plug) to get to the filter. First video was my original inspiration. Never had a problem using this method.
akras
PA
Why bother changing the oil and not the filter?
Because we are talking about ATF change, not engine oil, and changing filter on this transmission is a bit more involved than just changing ATF, requiring pan removal...
DieselMonk
Atlantic Canada
Yeah, exactly why I’d do that. Just a fush is wasted $$$ and the tranny filter and extra work is much cheaper than any repair. There is heat and wear and tear items in the transmission too! Depending on how hard you use your vehicle I guess. I change transmission oil and filter at 80k or 10 years.
akras
PA
... Just a fush is wasted $$$ ...
Seeing the state of my ATF after 60 or so kmiles I totally disagree with you. It's easy to swap ATF every 20-30K, but I don't see any reason to change the filter that often.
DieselMonk
Atlantic Canada
When I was driving my diesel 3/4 ton years ago and a max load trailer towing, I changed every 30k fluid and filter. All depends on how hard you are on the tranny. However there is no lifetime oil and no lifetime wear parts in the transmission.
With my spirited driving style and no trailer towing, my transmission oil and filter are due at 80k to 100k and follow the severe schedule. Same for engine oil… change it ever 5K with the filter. But why sending new oil through an old, dirty filter?
bring_em_on
bring_em_on
MD
akras
PA
From the filters I've seen, these aren't true "filters" so much as they are a screen. Kinda like how K&N air filters are "filters" but I would never drive across the Mojave with one. If you look at the "Other names" listed on the Ford parts page, they even call it a "Screen".
They are proper filters, and they are not primitive ones (they even include a magnet). They should be replaced every now and then, but not as often as ATF.
Not sure why you posted a link to an irrelevant part. The proper one looks like this: https://www.fordoempartsoutlet.com/...MI19n2trOLlwMVXFtHAR2YcgVJEAQYAiABEgLAhPD_BwE
bring_em_on
bring_em_on
MD
gunner1416
