How many miles did you get out of your factory brakes?
Shaggy
Administrator Moderator
Arizona
Quick one for the 4th gen guys. How many miles were on it when the original pads and rotors were done, and what did you replace them with? Towing probably makes a big difference so mention it if you pull something.
DieselMonk
Atlantic Canada
My rear brakes were shot disks and pads. My top pic for aftermarket brake pads and disks is ADAPTIVE. I use them from wifeys BMW, to trucks and SUVs. NAPA has them. They are cheaper and at least as good, if not better than OEM. Even run them on a Benz with Brembo brakes.
byathread
Pennsylvania
The 2019 ate brakes/rotors. I towed a 7K Travel Trailer and that contributed along with driving hard. When I dragged it behind the RV, that ate pads also mainly because of how the braking unit worked. I did have my Ford dealer just replace w/OEM stuff and also had them do the job again (twice/two separate occasions) when one pad wore way faster than the other (their crap job/parts).
I'll also just chip in that totally depends on use case as to wear frequency. I bet someone could easily get 100K out of a set of original pads/rotors if their use case was amenable to that. Others would need to replace at 25K (like my use case).
My 24 seems to be fine so far w/about 24K on the clock. Time will tell/not towing it or really anything regularly with it however!
Meeker
Calgary, AB, Canada
My 2018 original rear brake pads lasted until 143,000 km. I didn't even replace the discs... But now I see nothing about replacing the front in my maintenance record (now at 191,000 km) which makes no sense. I need to check my receipts...
I've towed my 7k lb travel trailer about 18,000 km during that time. But I drive fairly lightly most of the time... I put on Michelin AT/2 tires at 38,000 km (to improve trailer towing) and i'm still on them after 153,000 km so I'm not hard on equipment!
Al_Harley
