How many miles on your 2nd Gen Ford Expedition?
Loudpedition
Hobe sound Florida
Texasscot it is the 5.4 they had ford dealer put it in 5 years ago
Didnt get reason for it but assumption is original pooped the bed..
Just got paperwork from Ford for the swap
Along with stack of maintenance records and title
but expy sat over 2 years under a metal carport deal un moved. I have noticed ac changing between defrost and vents on its and blowing ice cold from defrost more often last 2 times driving it. So I assume a vaccum line is faulty but
Southeast
Service mechanics for fleets have stated the 5.4 can easily reach 350 to 400 k miles before requiring a full tear down. That said, one should expect to service timing components and oil pump, inspect the cams and liters for wear, every 90k to 100k miles. Further, one should inspect plugs on a shortened interval of 30k miles
AntMan201
230,000 here
just changed all 8 spark plugs and ignition coils and O2 sensors, fuel pump and DPFE Sensor (causing all sorts of issues)
bigdogchrisl
Fort Collins CO
230,000 here
I just changed all that in mine, including DPFE - and it appears to have created all kinds of issues as well. Truck races at startup, then virtually stalls, then hunts...none of which occurred befote, which I just chalked up to my incompetence by missing a vacuum hose or something, but all hoses are correct and I didn't have this after changing the intake at just over 186785 miles....
Sent from my SM-N986U using Tapatalk
