how much weight can I haul- '24 Stealth 304A
haviland
MA
This newer vehicle is very much the same as the '22 Stealth 304A I recently lost in a wreck. I towed my old boat (26' Formula 260SS) weighing approx 7,740 pounds including the trailer. I used a regular hitch around town and an Equalizer weight distributing hitch on the interstates.
I found a replacement Formula with those same dimensions and wonder- DO I REALLY NEED A WEIGHT DISTRIBUTING HITCH, especially going 65- 70mph?
Anyone with similar vehicle and similar weight boat?
Thanks
H
haviland
MA
The information I read said my vehicle can safely tow up to 9.000 pounds without a WDH. My loaded boat and trailer come in at abut 7,200 pounds.
However, I was hoping to hear from people that have had actual experience towing trailers in the 7,000 pound range with Expeditions with the heavy duty towing package.
Anyone with similar situations?
C Trost
Maryland
‘20 XLT 18in rims, HD Tow, B 5100s rear, rear sumo springs, helwing rear sway bar. Tow 27 ft express cruiser 8726# total w/ trailer. No WDH (not recommended by trailer OEM). Expy tows great. Just got back from a 1460 mi tow over the App Mt and back. Expy was great, no issues, 60-65mph, 55 up the long steep grades. Trans was 205-208 w/ peak at 217. 3 long legs got 10.9, 12.2, 11.0mpg. Run premium gas, it does better than 87, mileage and power is better. Check what that model cargo capacity is; should be on the driver door frame, mine is 1680#. GCVW for ‘20 is 15,500lb
Grrumpy
Navy Law Enforcement
Read your owners manual.....limits are spelled out.....
When equipped with the tow package, your limited to 6000 lbs WITHOUT a weight distributing hitch set up.
To tow the max or over 6000 lbs it indicates you need a weight distributing hitch set up. There is no difference in the required hitch whether a travel trailer, boat trailer, cargo trailer.....over 6000 lbs you are supposed to use a WD hitch.
I tow a 7000 lb, 28 foot travel trailer and would never attempt to tow that weight/length without one.
Also....and this is important....there is a sticker on the hitch bar on the truck that indicates several capacities....one is the weight limit when using a WD hitch and one is the weight limit without one....the limit without a WD is 6000 lbs. This is not a restriction based on the vehicle but a restriction based on the hitch platform itself. You can tow more with a WD set up simply because it is transferring weight to the vehicle while without a WD the hitch is basically towing/supporting the entire load.
Your tongue weight limit is also affected.....without a WD the tongue weight is 600/630 lbs depending on a regular or extended model. With a WD hitch the tongue weight raises to 900/930 lbs depending on model.
I have a 2019 with the tow package and the ratings are exactly the same as the 2024.....
gunner1416
