How To: Center Console Refrigerator Install
HILLY
Greenville, SC
I recently caught wind and posted in another thread that Dometic had their F-150 console refrigerator on sale. As in at $100 at the time of writing this is practically giving it away. It's a respectable brand and are also from what I understand sourced by OEMs to provide solutions. I had always been interested in having one for family travels (we drive vs. fly) and always liked what I saw in the LC200's and LX's that they were common in. I quickly researched this model and liked what I saw and the feedback from the F-150 crowd was pretty much all positive.
The product came fairly well packaged within the box. On top of the packaging you should have the plastic cutout template, exhaust fan, and plug (to cover hole in future removal).
After reading the instructions which were rather straightforward, I got to work cleaning out the console of belongings and prepping for the hole cutout for the exhaust fan. Remove everything including the bottom console pad. I taped the template to the console where the 12v socket is. I then took a silver Sharpie marker to trace out the outline of the template for a "just-in-case". Took a 3.5" (89mm) hole saw and aligned the pilot bit to the center of the template to begin the cutting. Once I had a good initial drill with the pilot bit, I removed the template to finish the rest of the hole cutout. I started with the drill in reverse to score the plastic and kind of set a groove for the saw to follow when cutting. I drilled several seconds at a time to check my progress and vacuum out the shavings. Once you get through making the primary hole, there is a strengthening rib that is on the backside of it that end up snipping off. Also be careful not to "punch through" as there is a harness - clipped back - rather close to the RHS of the hole opening.
After the hole is made and shavings vacuumed out, I installed the exhaust fan while orienting the harness to the 2 o'clock position.
There are two foam braces that now need to be installed on the LH & RH side of the console bin to provide bracing/spacing for the fridge. Not provided, but I grabbed some alcohol wipes and cleaned the hole area around where they would be adhered to. These are easy to line up and install as they just sit on the "ledge" around the bottom.
The final part is dropping the unit into the console. This help to have another set of hands so as not to accidentally drop. The unit runs off the 12v receptacle inside the console, so that needs to be plugged via the short coiled plug. Then the exhaust fan that was mounted to the console needs to be plugged in as well. This is where it helped holding the unit halfway in the console while the other person plugs in. Once that's done carefully drop into place. The unit needs to tilt towards the back and slip in under the rails for the console tray. Then lower the front down so the front lip rests on the front tray rail. Using a screwdriver, twist the clips 90* to lock in place. Install the trim panel and done.
HILLY
HILLY
Greenville, SC
Fit and finish on the completed unit is fantastic. Really does look OEM as it should. The unit powers on via the button on the front driver's side of the unit. It will run as long as the last status was on; as long as there's 12+ volts measured; and obviously as long as the accessory circuit is active.
The lid is magnetic, so rather simple and easy. No latch to get damaged and wear out. There is a sealing ring on the lid to keep the air tight. After about 15 minutes of run time the compartment got rather frosty and can be seen in the picture.
There is not much room between the console lid and the unit. Space in the front portion to put small belongings (pens, etc.). I couldn't get my phone to sit in there and you can't block the vent on the driver's side of the trim.
There are two USB-A outlets. I haven't tested them as to how well they charge and probably won't use much as I hardly used the 12v plug in the console as well. They are a bit dated at this point as I see the MY21+ F-150's now have USB-C.
Overall, for the $100 this cost, I think it was a pretty solid buy. I think I saw in some articles that when it first came it it was more like $800. If I don't like it in the end, I'm only out $100.
Pro's:
- It's cold! It gets frosty. This actually runs on R-1234yf refrigerant.
- It's reachable! I can now go on a trip without trying to get one of my kids attention for a drink in a cooler all the way in the back (they're all wearing headphones with noise cancelling, so can't hear nothing).
- Looks OEM.
- Fit and finish I don't think can get better.
- Holds about 12 cans with of drinks
- It can be removed somewhat easily if need be. They also supply a cap to plug the hole that was drilled out.
Con's:
- Takes away your console space. Granted, you can probably turn it off and still throw things in there if not planning on using it for day-to-day driving and clean out to use on trips.
- If redesigned, could have had a removable basket to contain stuff (like cold sandwiches) above a first layer of cans. Another though would be a removeable basket to throw belongings in when not using the fridge function and remove when for when in use.
bb37
Super Moderator
Member Relations Specialist
Indiana
I think you've convinced me. I'm not 100% sure that I have need for this cooler, but at $100 for a quality unit, why not!?!
For someone that's on meds that require refrigeration, this would seem like a good idea.
HILLY
HILLY
Greenville, SC
That's also a very good point, never thought of that.
bb37
Super Moderator
Indiana
Is the 12v outlet in the console bin powered all the time or only when vehicle is running?
HILLY
HILLY
Greenville, SC
It has a timeout. I can't remember what it is but I believe it is around 30 minutes in general. I've seen various threads on what it is (30, 60, 75...). So either the Dometic will sense a drop below 12v and turn off, or it'll be dependent on the timeout of the power point.
The power point timeout can also be modified in FORScan. I'm not sure if that is an all-for-one thing or just some.
Also, the BMS has final say in what stays running for how long. So the power point can 30 minutes, but if BMS senses this to be a problem, it'll shut it down early.
NevadaGeo
For my camping trips I bought a larger plug-in refrigerator. I like to keep my center console for organizing small things. The refrigerator plugs into either USB or 12V and works but definitely need to keep it charged up!1743863724313.png
East-TN
TN
Any experience on how hot the center console area gets with the fridge running during a trip? Any noticeable difference?
kep5niner
MO
I just picked up a 2019 Navigator. My wife and I were on a trip to FL, and our rental was a new Wagoneer that had a fridge in the console. She really liked that! So yeah, for $100 this looks like a great upgrade.
Does anyone know if the console of the Navigator is the same as the Expedition? I just picked up the Navigator, and now I’m on a trip for work - so I can’t confirm dimensions of the console. Thanks for any feedback!
130tucker
Fairhope, AL
Just ordered one. I hesitated because of having a MY22, but this clears it up.
I know several folks with Expys. May order a second and charge an extra $100 for install.
When I get it in, I'll see about designing and printing a basket for elevated storage.
JimmyC
New Hampshire
What year did you install this in?
Confirm you put it in an Expedition?
I’ve had a Dometic cooler god my boat got over 10 years, it works like a charm.
Very high quality
HILLY
HILLY
Greenville, SC
omandave
Puget Sound, PNW, WA
I just pulled the trigger today 4/7/2025... $108.80 including sales tax...
So worth it, even if I end up not liking it in my 2019 Expedition... I can always install it elsewhere...LOL
Gregg Eshelman
Idaho
Where do I order one? Won't fit in my 2007's center console but I could make a nice box to drop this into to make it a cheap portable refrigerator.
omandave
I did a search on google for Dometic F150 console fridge.
the link I got was this:
from their listing when you click read more:
The innovative Dometic CCF-T Center Console Refrigerator seamlessly integrates into your center console to offer you the ability to add an integrated refrigerator to your Ford F-150 (2015-2020), Ford Super Duty (2017-2022) or Ford Expedition (2018 & Newer). Now you can bring more of the food and drinks you love, wherever you go with the CCF-T compressor-based center console refrigerator.
wakeboarder
Fort Lauderdale, FL
For those who want to make a portable cooler that doesn’t live in the center console, this one may be easier to incorporate into a housing. It seems like it may have more square sides. https://a.co/d/aCzaN0Q
It does not fit the expedition center console.
