Cindy Zaka
how to tell you are in 4x4
You dont say which 4x4 mode so thats one thing. There is a way to lift the front wheels off the ground and turn one by hand and see something happen or not happen. Its too complicated for me! Yes you can observe the display and the Expy will inform you about what mode it thinks its in but it may not be working too. I ran a test the other day on a snow covered parking lot. From a dead stop ... put it in 2WD ... then accelerate (enough to spin wheels, nothing crazy) and see how it performs. Then put in an AWD or 4WD mode and repeat, you should be able to observe a noticeable difference. If in 4LO on dry pavement , front wheels will bind and jump if turning. Not advised but it IS a test. In summer you could back up the rear wheels onto wet grass with front on dry pavement and step on it. If 2WD then rears should spin and you dont move much.how to tell you are in 4x4
In 4W (at least in my 05) you will feel the front wheels binding and releasing if you turn tight on asphalt.
