How to turn OFF/ON seat belt chime
Habbibie
Is it Christmas yet?
Chicago
You can Deactivate the Belt Minder two ways. First, you can deactivate it temporarily for your current "run cycle", that is after you have started your car and it's still running. Second, you completely deactivate the Belt Minder so that it never reminds you again, or at least until your reactivate it...
The first method, temporary deactivation, or one time disable: After you have started your vehicle, buckle and then un-buckle your safety belt. Be sure to buckle back up.... This will disable the Belt Minder only for that ignition cycle.
The second method, permanent deactivation: There are 9 steps you need to follow to deactivate or activate your Belt Minder system. Before doing so, make sure that:
  • The parking brake is set.
  • The truck/car is in Park (automatic), Neutral (manual).
  • The ignition is OFF.
  • All doors are closed.
  • The driver's safety belt is un-buckled.
  • The parking and headlights are OFF.
Then follow these 9 steps:
  1. Turn the ignition switch to ON, but DO NOT START.
  2. Wait for the safety belt warning light to go OFF(1-2 minutes).
Steps 3-5 MUST be completed within 60 seconds!
  1. Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled.
  2. Turn on the headlights, turn off the headlights.
  3. Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled.
After step 5, the Safety Belt Warning Light will be turned on for 3 seconds.
  1. Within 7 seconds of the safety belt warning light turning OFF, buckle then un-buckle the safety belt.
This will disable the Belt Minder if it is currently enabled, or enable the Belt Minder if it is currently disabled.
  1. Confirmation of the disabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds.
  2. Confirmation of the enabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds, followed by 3 seconds with the safety belt light off, then followed by flashing the safety belt light 4 times per second for 3 seconds again.
  3. After confirmation, the deactivation/activation of the Belt Minder procedure is complete.
videos are for F-150 but works on expeditions as well.
2nd gen expys
It worked on my 05 expy
3rd gen expys
Worked on my coworker's 07 expy
I'm an electrician and from time to time I have to service light poles there for I'm in and out of the truck every 50 yards and its the most annoying thing to have the beep going Off continuously
Bedrck47
Elizebethtown, PA
My 98 don't have a chime
The following was copied from the 98 Expedition Owners Manual
Safety belt warning light and
indicator chime
The seat belt warning light
illuminates in the instrument
cluster and a chime sounds to
remind the occupants to fasten
their safety belts.
Safety belt
Momentarily illuminates when the
ignition is turned ON to remind
you to fasten your safety belts. For
more information, refer to the
Seating and safety restraints
chapter.
Does you seat belt illuminate in the instrument cluster??
Ed_Strong
SWFL
Don't know if Ford did this across the board with all models for any particular year... but on my 2000 Ford Windstar, all I have to do is push the red un-buckle button on the seat belt while on the un-latched position and this would stop the seat belt chime for the duration of the (run) cycle. after the key is turned to the off position and back on, the chime would resume warning again
Crazys98eb
Beaver county
indicator chime
their safety belts.
Safety belt
chapter.
Not sure I'll have to check
Habbibie
Habbibie
Chicago
Not sure but does turning off the chime turns off the air bag deployment if I'm buckled in and I wreck head on? Cause when I programmed it off the air bag symbol blinked rapidly along side the seatbelt symbol?
