Image size
Shaggy
Administrator
Arizona
All,
Just a few notes:
If you want a photograph to show up next to your username, go into User Cp from the menu, the click on Edit Options, then click on Change Avatar. The image you use can only be 100 x 100 pixels max. So moist likely, you will need to resize it with a photo editing program.
Also,
I will be changing the size max size of pictures allowed as attachments. to 100k Bytes. If your pictures go missing its because of the limitation on size. Just repost them as again as smaller files. I am doing this because this could be a problem in the future.
Thanks,
JT
