jmden
Is there a way to increase the front axle GAWR (Gross Axle Weight Rating)? Anyone explored this? I have a 2014 with 108K on it. Front GAWR is 3550 lbs, just like the Gen 4s I've seen.
Have a front hitch. When I put a motorcycle carrier and a 280 lb motorbike up there and have a passenger up front I am just over the GAWR with a 110 lb double kayak up top that is 22.5' long and towing a 19' trailer.
All the other weights are well under max when we get to the scale and weigh and figure everything out weight wise. I think I can reposition some cargo (get more weight in the very back of Exped) and the locate the boat rearwards up top to get under the GAWR...maybe. I do have 10 ply rated tires up front that I run at 65 psi plus with bike up there and/or towing. I was able to reposition the bike 2" closer to the front of the Exped by drilling new holes in motorcycle carrier.
I have installed the SumoSprings up front in the coil springs, otherwise the front dives badly.
I'm curious if anyone knows what component is the 'weak link' that rates these front ends at 3550 lbs. Struts, axles, etc...? Anyone know and is there a way to functionally increase that over what I've already done?
