Jake Oleszak
Hello all. 05 Expedition EB 4x4 3v V8.
I’m wanting to remove my instrument cluster for two reasons. 1. To replace the cluster bulbs because I have one burnt out; and 2. Fix my LCD display which has dimmed down to invisible (I’ve read it has a cold solder that needs repair, too easy).
Will removing the cluster trigger the PATS?? Or will it be fine since I’m putting the original cluster back in?
Also, because I haven’t been able to find a SOLID answer, what bulb size and how many do I need for the back of the cluster? I’m looking for original bulbs, not LEDs. I’ve searched forums up and down and the most common answer I’ve seen was #74 bulb, but this was argued. Others said #2723, #194 (which is absolutely incorrect)... please help. I don’t want to order a bunch of wrong stuff and have to remove the cluster multiple times.
Thanks.
Thanks.
