Intake Manifold 2003 5.4L 2v
Discussion in '2nd Gen - 2003 - 2006' started by JuniorExp03EB, Sep 9, 2019.
  1. JuniorExp03EB
    JuniorExp03EB Full Access Members
    25
    106
    Apr 1, 2018
    Chicago, IL
    Are these gaskets oem? left side is burnt? was loose and right side was over torqued. i think found my culprit for bank 2 lean. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my SM-N960U using Tapatalk
  2. JuniorExp03EB
    25
    106
    Apr 1, 2018
    Chicago, IL
    is that little bit chipped off cause the coolant leak.? should i also replace the manifold?[​IMG][​IMG]
  3. ExplorerTom
    ExplorerTom Full Access Members
    1,618
    538
    Apr 2, 2015
    Colorado
    Looks like the Dorman gaskets that were on my POS Dorman intake.
  4. JuniorExp03EB
    25
    106
    Apr 1, 2018
    Chicago, IL
    I got another one for you guys check this out
  5. JuniorExp03EB
    25
    106
    Apr 1, 2018
    Chicago, IL
    70369575_2436679956380167_7954049565542318080_n.jpg 69795722_2436679913046838_6389486262004219904_o.jpg 69755744_2436679859713510_3583892317200711680_n.jpg 69892517_2436679819713514_7285937307813675008_n.jpg
  6. JuniorExp03EB
    25
    106
    Apr 1, 2018
    Chicago, IL
    do i have a 2007 5.4 fuel rail? and why does it look like there a vacuum line going to a gas line.... what...
  7. bsutton1705
    bsutton1705 Member
    35
    19
    May 4, 2019
    Arkansas
    My 2003 5.4 fuel rail looked the same (I just replaced my intake). The vacuum line is for the fuel regulator. I would replace the intake if it has any kind of distortion.
    JuniorExp03EB likes this.
  8. JuniorExp03EB
    25
    106
    Apr 1, 2018
    Chicago, IL
    New gaskets in. short term and long term trim dropped below 30% but still set off p0174. idle got way better and can rev rpms higher.
    maf sensor seems to be a culprit.? could it be possible? how can i diagnose.
    just got hit with a tensioner tick. **** timing chain rehaul soon too.
Share This Page
