Intermittent Random ABS light
BROKENPILOT
TEXAS
Does it happen to occur during rainy or wet road conditions, or just all the time regardless of ambient weather conditions?
Beachums
Indiana
You don't even need a laptop. There is an android version of 4 scan. You'll likely have to catch it when the ABS light is on to get any insight.
My money is on a wheel bearing.
Trainmaster
Old School Member
Rockaway Beach, NY
Carefully check all your abs sensor wires for chaffing or rubbing against suspension components. Unplug and replug the sensor wires to check for a loose or corroded plug. Then, if you find nothing, do as Beachums says -- look at your sensors and wheel/hub bearings.
