Is my ‘14 going to fully charge an AGM battery?
J
jmden
Washington State
I've been running agm batteries in my old 97 dakota and my 77 gmc motorhome. Never an issue with state of charge. And using stock alternator in both.
Yeah, I get it but the reality is that AGMs require a bit more voltage than wet cell lead acid batteries to fully charge. It's a different charging profile than for wet cell lead acid batteries. My resting battery voltage is about 12.7V. I've been in contact with tech support at Odyssey and they confirm this is about 85-90% charge and never fully charging the battery is harmful to it. I may already have damage to mine which reduces the lifespan and capacity of the battery. This is why aftermarket alternator companies include a special voltage regulator that holds 14.8V if you have an AGM battery.
J
jmden
Washington State
Well... the only thing that hurts the vehicle would be installing the diode and then running regular flooded battery.
You don't happen to have an amazon link to the proper diode do you? There's so many different ones. I probably will plan on installing one rectifier diode, just want to make sure I get the right one.
Will this work: https://a.co/d/bF9op6Z
It sounds like I should just order a pack of diodes and install one (.4V) in the alternator sense line. This has got to be the easiest and cheapest option. And, I just got this from Odyssey technical support:
"3. Alternator Diode Trick:
Adding a diode to the alternator’s sense wire can indeed trick the regulator into a higher voltage output (usually adding around 0.5-0.7V). If you search forums, they have many options on how to achieve this. GM does it with a diode shaped like a fuse."
DieselMonk
Atlantic Canada
yes you are looking in the right direction. Can be something almost anything like a SB5100, 10sq100, 1N5401, MUR410 etc. maybe look at an old junk circuit board and rob one off. Look at the spec sheet of that diode and find the Forward Voltage. Higher this Forward voltage, the higher the regulator output.
The only problem this way is that you have to have the diode pointing the right way, because if the diode is backwards, it will block the sense voltage going to the alternator! If you get that diode that looks like a fuse and a fuse holder, you can easily point the diode the other way without playing with the harness.
J
jmden
Washington State
These should work, right? Folks are using these in YT vids for same purpose. Make sure the end that is grey is pointed to the alternator they say. Some YT vids are saying not to leave these in all the time if you have AGM batteries. It seems to me that as long as your voltage is at or close to 14.8V, leaving them in shouldn't be a problem, right?
DieselMonk
Atlantic Canada
Then put a switch to it, so you can switch the diode in or out.
My 24 charges the AGM anywhere between 12.8 and 15.0VDC. But the ECU is doing that in mine.
So in one way the die because undercharging and the other way from overcharging? Pffft.
J
jmden
Washington State
Why would I switch (link to suggestion?) the diode out?
DieselMonk
Atlantic Canada
There is no link to my last suggestion. I just came up with it in order to give an option to have both modes (AGM and flooded). All you need to do is make a wire bypass in parallel with the diode and a switch. Switch off = diode on (AGM mode), switch on = bypass the diode as the wire jumper completes the circuit in parallel (normal flooded mode).
I suppose you could also do that with a automotive inline fuse holder and a fuse in parallel with the diode. Fuse out = AGM mode. Fuse in = flooded battery mode. Power always goes the path of least resistance. When the bypass wire circuit is complete the power will go around the diode, rendering it useless so to say.
Or:
You cut the sense wire and install the inline fuse holder (with pig tails) into the sense wire. Buy that automotive fuse looking diode. Put the diode in the fuse holder = AGM mode. Put a regular 10 amp fuse into the holder = regular flooded mode.
J
jmden
Washington State
Or:
Why wouldn’t I just always keep the diode in so that it’s always in ‘AGM mode’.
DieselMonk
Atlantic Canada
Sure. I’ve got like 3 AGM batteries in cars and tractors that were not designed for AGM batteries. I just swapped the old flooded battery for an AGM and didn’t bother with the diode in the sense wire since the battery is only there to start the car / tractor. It’s not like an Overland or off road vehicle. How long did they last? I had an Odyssey AGM in the GT500 for 13 years (need a new one now), still run a Motormaster AGM in a tractor for 6 years , and a Magnacharge AGM in another tractor. Works fine so far. So this overcharging and undercharging theory on the internetis probably more unique to high current draw and drawing a lot of power in total over time situation. Everyone their own.To me I think it is more important to buy a good AGM battery and that isn’t always the case. An AGM handles more abuse than a flooded battery, true, but it will die at some point too. It’s also up to the owner to maintain a battery these days.
What is there to maintain on a AGM battery? You will be surprised what cleaning up the battery posts and the battery clamps will do, specifically on the newer vehicles. This gets forgotten fast.
A good AGM lasts you 6 years on a start stop vehicle and about 10 in a non start stop car. Ooofff… makes me feel real old now to be able to talk out of my experience with that crap.
J
jmden
Washington State
So while driving around with a voltage monitor/USB port adapter in the 12V power outlet, I’m seeing 13.9 -14.1 and it seems when we are driving in warmer weather (mid to upper 80s) that voltage is dropping to 13.6-13.7V. Does this make sense? Or, do I have an alternator going bad? It’s a OEM alternator that was replaced by dealership about 100k ago, at about 25k miles. I occasionally run a 50amp DC to DC charger off the battery and am already wondering if I’m asking too much of the stock 175amp alternator.
