Just curious?
wercsje1
Salem, OR
After making my changes to my 2021 Expedition XLT Max I now see DTC Codes with (!) mark. Is this normal? Changes I made were-
Global Windows
Turn signal increase to 7 ticks
Heated/Cool seat and steering wheel to Sync display
Turned of the doo-doo-doo
Bambi Mode
Mirror tilt
Heated steering wheel tem increase 90⁰
Removed the temp above gauges (even when the vehicle was cold it still stated 100+ degrees as a base temp, always off)
Post Reply
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Global Windows
Bambi Mode
Mirror tilt
Post Reply
When you scan with FORSCAN, what module are you seeing the DTC in, and what is the DTC. Those are important pieces of info for this question. Most likely you changed a code string that you shouldn't, but I need to know those 2 important pieces to attempt to help. Did you save your module data before you started making changes?
wercsje1
wercsje1
Salem, OR
I did save and did download the complete print out of all my original codes. I did a reset and nothing has come back on. I think it was 8 days ago when I was still just an infant with Forscan and I may have entered a number wrong but corrected.
airbrush
Florida
Hopefully, you saved a file with the original codes. I think you amy have to call up that file, load and write it, then save.
