Leaking by quarter window's
konny
glorida
Hello. Both of my rear plastic bins fill with water after big rains. Not just the bin part but also the cup holder a few inches in front of it. A see some warm drops coming from the bottom plastic of the rear pillar. When I went in the back while it was raining hard I could see the drops form on the edge of the headliner at the top of the quarter window. My truck is parked on an incline with the front slightly higher than the back. I'm not sure if that comes into play on why the water is in the rear. I ran a hose for a few minutes on top of the quarter windows. They are the fixed in place ones. I couldn't get any water to come in. I ran the hose for a few minutes in each roof gutter thing and couldn't get water to come in. Now I've taken off the roof rack and am looking for issues.
1. Those roof gutters. What is their function? Mine are curled up on the sides and look like water could find its way in.
2 what should I check next.
Thx
K
konny
glorida
Thanks. I read that one post where the dude used it with success. I guess if I use that on the gutters and quarter window uppers and address the 14 roof rack holes, I should be good
ptoliver
Soddy Daisy
I've got the same problem 2008, You tube said to remove rack, seal internal nuts with silicone, and use good quality Teflon tape on the bolts, I did this but still have leaks. Sprayed with water around the upper stationary window and leaked steady drops onto the cup holder. Has anyone sealed the fixed window that has a attached gasket without replacing the window. I ask Safelite, they said it cost $700 to fix, what a rip!
llldatlll
